Civil 3D Forum
corridor error message
3 REPLIES 3
WinJC
277 Views, 3 Replies
I recieved this error message after I rebuilded my corridor
" Update macro file location to path defined by AECCCONTENT_DIR environment variable. (Source C:\ProgramData\Autodesk\C3D 2011\enu\C3DStockSubassemblies.dll!Subassembly…"
Does anyone know what I should do to correct this issue?
3 REPLIES 3
gknobbe
in reply to: WinJC
Try the convert vba to .net under the corridor utilities see if that fixed the problem
WinJC
in reply to: gknobbe
Thank you, I already converted to .net when opening my drawing.  What ever it was it seemed to fix itself.  Thanks for your answer though.
Jeff_M
in reply to: WinJC
This is a message you normally see when opening a drawing last edited in a previous version of C3D. It is not an error, it is just for informational purposes. C3D2011's subassemblies DLL file is located in a different location than C3D2012's DLL, so this is just telling you that it has updated which one it will be using.
Jeff_M, also a frequent Swamper
Rail Community
