I recieved this error message after I rebuilded my corridor
" Update macro file location to path defined by AECCCONTENT_DIR environment variable. (Source C:\ProgramData\Autodesk\C3D 2011\enu\C3DStockSubassemblies.dll!Subassembly…"
Does anyone know what I should do to correct this issue?
Thank you, I already converted to .net when opening my drawing. What ever it was it seemed to fix itself. Thanks for your answer though.
This is a message you normally see when opening a drawing last edited in a previous version of C3D. It is not an error, it is just for informational purposes. C3D2011's subassemblies DLL file is located in a different location than C3D2012's DLL, so this is just telling you that it has updated which one it will be using.
