Civil 3D Forum
corridor editor stationing problem not every 20m
5 REPLIES 5
wang890
287 Views, 5 Replies
i have corridor sampled every 20m and the view/edit corridor "select a station" shows every 40m. all in between are missing. it is set on all region stations.
so many mess ups every year.
more bloody slow as well.
Stantec
Dell Precision 5530, Prism M320PU, C3D 14/17/19
5 REPLIES 5
kiyabole
in reply to: wang890
Did u check at wt spacing ur corridor is built? it might be at 40m> tht might be the problem.
Kiya Chemeda
Civil 3D 2013
HP Pavilion dv6 cor i7
16GB RAM
windows 8
BrianHailey
Are these sample lines or the frequency of the corridor?
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
wang890
not samplelines. corridor frenquency is set to 20m but in the corridor editor it is every 40m.
Stantec
el.Topo
did you have a look at the:
corridor properties - parameters tab - set all frequencies - apply assembly - along xxx values?
these are the parameters controlling the corridor section editor station intervals... I think...
MacBook Pro, Intel Core i7 CPU M 620@2.67GHz, 8GB RAM
W7Pro SP1, 64-bit / Civil3D 2016
Jeff_M
Maybe THIS applies to your case?
Rail Community
