Where can I find the corridor display tab/settings?
Some things, like surfaces and such, are easy to find, but for the life of me I cannot find the location for settings corridor layer & linetype & color settings (display tab).
One of my last holdouts from LD is to manually draw my curb & gutter linework and ignore the lines the corridor would create for me. I basically used the corridor lines as verification, not their full use. I decided to break from this habit, then spun my wheels trying to locate where these settings might be.
Thanks.
Solved by Jeff_M. Go to Solution.
Click the corridor, right-click and choose Edit Corridor Style.
@Jeff_M wrote:Corridor properties, Featurelines tab, Code Set style and Featureline styles.
That's it. Thank you.
Mini rant: I like C3D overall, it's very powerful, but display options are not as uniformly straight forward as they should be. /mini rant off
