Does anyone have a good way of handling overlapping of corridor daylight lines @ PI's and curves? It seems like grading objects handle these overlaps much better.
Michael
Corridors do not clean up overlaps like grading objects. A few workarounds that come to mind are:
Manully edit the corridor sections
Create a featureline where you want the corridor to daylight, drape it on EG and use it as a target for the corridor daylight assembly
Extract an edge featureline from the corridor and use gradings to model the daylight in those areas.
Thanks Neil. In the past, I have used grading objects in these tight spaces. I wish I didn't have to go through these extra steps, especially as the cooridors get more complicated.
I guess I'll have to put this on my wish list for future versions!
I have never taken a corridor through visualization and rendering, but I was trying to keep the corridor as much a complete model as I could (trying not to use feature lines and grading objects to fill in gaps), because it seems like I will be better able to produce a rendering in the future if I have a complete corridor.
Just wanted to throw that in to let you know why I was asking the question. Any thoughts?
Michael
There are a couple of options that you can apply to the corridor as I mentioned. I agree that this is one of several issues that need to be addressed.
