My corridor Feature Lines for Daylight Jump across in different areas (see attached PDF)
when I look at it in 3d it looks ok but the plan view the jumped lines show up
John Wilson
Solved by mathewkol. Go to Solution.
You may have some luck if you split your corridor into a few regions. I've attached an example of where you might split them.
Dear Matt
Thanks I'll try that. I also noted that if I play with the frequency distance it seems to reduce the problem.
I will try those locations you suggested.
Thanks again
I have the same problem in 2012.
When the bench lenght is smaller than the frequency I'm using, for example if the bench has 17m but my frequency is each 20m, then I can see the links connecting to another bench link some meters away...
Never found a solution for this besides spliting the corridor..
Mr Galgarezi
That a good point. I have some sharp turns that could cause that. I will put this in my notes
John Wilson
