I have seen this post many times over the past few years but I haven't discovered a real viable solution yet. So I'm trying again. What would it take to edit Corridor Code Set Styles to add a plan view elevation at specific sub assembly points. It seems like it should be a simple fix if a marker can be displayed.
I really like the ability to label spots in section view in this manner but I would like the capability in plan view. LDT did swimmingly well with this by bringing in template points along an alignment at sampled stations. Our local government requires these elevations on plan sets and it would sure save us alot of time if we could get this option back.
Any responses would be greatly appreciated. Thanks in advance!
@dnth8 wrote:
..... LDT did swimmingly well with this by bringing in template points along an alignment at sampled stations.......
You can create Points along a Corridor, and you can specify which code(s) to import (so you don't get all of them which wouldn't be needed). Set your corridor frequencies to be at the desired interval, then create the points. The command is: AeccCreatePointsFromCorridor. On the Ribbon, it's under the Launch Pad of the Modify\corridor Tab
Thanks for your help. I have tried to approach it in that manner. However, the point elevations aren't dynamicly updated with the corridor and if the alignment has curves, the points won't rotate with the alignment.
This is why I would like to see something with Code Styles.
There wasn't a lot of dynamic going on in LDT. I did have a lisp routine for rotating all the points to an alignment. I was just asking a question looking for a solution. (or another work around)
I really appreciate smart alec comments though. Everytime I have ever posted a question on this site, some jerk has something smart to say!!!!!!!!!!!!!!!!!!!!
But you can use point>> edit points>> elevations from surface. Not dynamic but is your project that complex to have to remember?
Joe Bouza
Another approach (and you may like this one) could be create alignments from corridor and generate the dynamic profile from surface. Now you can make an alignment label style that can label profile elevations that would be dynamic with the corridor.
Joe Bouza
I would also like to have the option to add a label to a corridor link in plan. I understand the workarounds but it would be much more efficient. For example, currently I want to see what grades the Daylight_General is using in plan without having to open the corridor section editor or plotting out sections.
That's the ticket Joe. An alignment will work dynamically and keep the labels rotated to the objects. A Feature line would also work.
John Mayo
