Civil 3D Forum
Corridor Building Problems
3 REPLIES 3
99 Views, 3 Replies
Ok, so I have a corridor. If all the regions are checked on, I get some
feature lines going across regions. As you can see in the attached image,
the corridor create feature lines from the end of region 3 to the begining
of region 5. However, if I uncheck region 1, it works as desired. Anyone
seen this before?
Nick, you want the drawing to look at? I can't post it to a public forum
but I'll send it your way if you want to look at it.
Brian
http://www.ctcivil.com
http://cadcafe.blogspot.com
3 REPLIES 3
Oops. Forgot the image.
Brian
"Brian Hailey" wrote in message
news:5620807@discussion.autodesk.com...
seen this before?
Brian
never seen that one before....did you find any Solution? Id be real interested in it...
Matt Wright
Pacficad Inc. null
nzeeben
Is this like bait the Autodesk Employee? Am I about to be setup on Punk'd? Send it over I will see if I can pry it apart.
Nick
Rail Community
