Im designing a trench which was created with subassemblies that will be under an existing ditch.
The problem is that I need the excavation shown. When I paste the surfaces the ditch grades up to the top of the trench. I attached some photos of how it looks pasted. It should look like photo 1, but the ditch should be graded like photo 2 continuously so it just drops off into the trench. Both of these are corridors. If i could use a portion of one corridor as a boundary to another that would probably help but im not sure.
I have pasted surfaces
played with the regions
created a tin volume surface and used it as the boundary
The paste order is important. Did you happen to try and paste it the opposite way you did?
I thought you said you were pasting the surfaces? Pasting surfaces and created TIN volumes are very different.
See if this helps...
