I am learning how to create corridor, and I have a question about assembly elevation targets.
When creating a corridor, the profile is required as dependent object, which gives the elevation of the centerline
of the road. Based on the definition of assembly, the elevation of the corridor at the offset targets can be determined by the
the profile. My question is if the assembly elevation target specifies the elevation at the offset target too? If so, why both profile and
assembly elevation target are required?
Thanks!
Xiangyu
Some subassemblies such as LaneSuperelevationAOR support optional "Target Parameters".
These are not required. For example, if you don't want the elevation for the lane edge to be set by the
constant lane slope set in the subassembly, then you can target a special Profile that will determine
the lane edge elevations.
Thanks for the reply.
The assembly used in the project has two subassemblies, LaneInsideSuper and LinkSlopeToSurface.
One side of the road has to be tied to an exisitng surface, because it is an expansion work.
The offset target is about one or two meters from the edge of the lane. Therefore the elevation target
is required for the LinkSlopeToSurface subassembly. The profile for that road alignment is designed based on slope requirements.
I just wonder how the surface will be created with both centerline profile and the elevation target? I mean if the
elevation target is specified, will the elevation of the center of road change with it, and be different from the elevation
given in the profile? If so, that means the actual profile will be different from the design.
Thanks!
Xiangyu
@Anonymous wrote:
I mean if the elevation target is specified, will the elevation of the center of road change with it, and be different from the elevationgiven in the profile? If so, that means the actual profile will be different from the design.
No, the FG Profile set at the Assembly Marker or Alignment location will control that particular location based on the specified FG Profile.
Any "Target" Profiles assigned will control the point at which they are applied to a given subassembly which supports vertical targets.
Pressing F1 key while hovering over any Subassembly will bring up help for that subassembly.
For your Surface question - We can better understand what your trying to accomplish here if you post a screen capture of your design.
Thank you, Jay! I think I figure it out.
In your first reply
"if you don't want the elevation for the lane edge to be set by the
the lane edge elevations."
My understanding is if the target elevation is set, the slope in the subassembly is ignored. Is that right?
I attached a snapshot, the road is 8 meters wide, the dashed line is the center of the road.
The red line is the edge of pavement attached to exisitng surface. The blue line is the edge of pavement
not attached to existing surface.
Merry Christmas!
Xiangyu
Correct.
