Civil 3D Forum
Corridor Assembly appears flat in Sections???
8 REPLIES 8
Message 1 of 9
1047 Views, 8 Replies
I have created a proposed centerline along my existing roadway, which represents along my profile. I have created an assembly for my proposed raod with a crown, and a 2% cross-fall in each direction. But when I generate my sections, all my proposed assemblies show up in the proper location on my section views, except there is no cross-fall showing on any of them??? They are all being shown in my sections as dead flat! 0%??? I've been looking for a setting to change this, but cannot find the answer??? I have also deleted, and recreated my corridors and regenerate my sections, only to get the same results!?!
I would appreciate any help.
...I am using C3D 2012
8 REPLIES 8
Message 2 of 9
kfurn
Try going to your Assembly properties and edit the values. Of course, you would need to recut your sections.
Good Luck,
Kevin
Message 3 of 9
in reply to: kfurn
Thank you for your suggestion, ...and maybe what you are saying is correct, but I've tried adjusting values within my assembly properties and re cutting them, but there was no change??? I'm sure there must be some override setting or something that I can not seem to find???
So, to clarify, everthing looks good, except there is no 2% cross fall showing on my generated sections, even though there is cross fall indicated on my assemblies. And the location of the crown (if there was one) is showing up at the correct elevation, ...just no 2% fall, ...totally flat?!? So frustrating!
Message 4 of 9
kfurn
If you're using the right parts to build your assembly, it should work. Sorry I couldn't be more help. -Kevin
Message 5 of 9
Jeff_M
Can you post, or email, your drawing? jeffm AT quuxsoft DOT com
Jeff_M, also a frequent Swamper
Message 6 of 9
Jeff_M
in reply to: Jeff_M
For those follwoing along, the cause of the flat sections was due to using the same profile for the outside lane profile targets as the centerline profile.
Message 7 of 9
kfurn
in reply to: Jeff_M
That is correct. -Kevin
Message 8 of 9
So, did you create a profile at an offset?
Message 9 of 9
in reply to: Jeff_M
Hey Jeff, I know its been a while, but how would you go about fixing this problem?
O.R.
Rail Community
