Civil 3D Forum
Corridor and Essembly Daylight
15 REPLIES 15
Message 1 of 16
SeattleCADD
698 Views, 15 Replies
Please help: I am creating a corridor with a simple assembly. On my assembly, I have basic lane and daylight Multiple surface. My target is existing ground. I don't know how i can explain, but please see the attached bitmap file.
Thank you very much for your time!
Dennis
15 REPLIES 15
Message 2 of 16
SeattleCADD
in reply to: SeattleCADD
i forgot the attachement!
Message 3 of 16
Jay_B
I'm not too familiar with the DaylightMultipleSurface but it's capable of targeting 3 surfaces so it's possible you've set the target EG for all three target options.
Try using DaylightGeneral if your looking to keep it simple as this daylight sub only targets one surface.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 4 of 16
fcernst
Set your Intercept Number to 1.
Fred Ernst, PE
C3D 2024
Ernst Engineering
www.ernstengineering.com
Message 5 of 16
Jay_B
in reply to: fcernst
I didn't see that parameter in the DaylightMultipleSurface sub?
C3D 2018.1
C3D 2016 SP4
Message 6 of 16
fcernst
in reply to: Jay_B
You're right... I thought he was using MultiIntercept there for a minute.
Try using MultiIntercept.
Fred Ernst, PE
C3D 2024
Ernst Engineering
Message 7 of 16
don.ireland
There's one thing I noticed in your picture:  you point to what is basically the SECOND intersection of the slope and EG and say that you want to "connect here at the first intersection".  So I'm a little confused.
Message 8 of 16
fcernst
That is the first intercept right of baseline control cross section station 0 where they want to stop.
MultiIntercept would be a good useful implementation with this undulating EG slope.
Fred Ernst, PE
C3D 2024
Ernst Engineering
Message 9 of 16
SeattleCADD
I have set Intercept Number to 1, but the cut is still cut beyond the first intercept. I could not attach the file because it is too large. I can email to your email address if you wanted to help me!
Is there any other daylight i can use for my simple cut and fill: Cut 1.5:1, Fill 2:1 to existing ground surface?
thanks,
Dennis
Message 10 of 16
fcernst
Yes, send it along.
Fred Ernst, PE
C3D 2024
Ernst Engineering
Message 11 of 16
SeattleCADD
What is your email address?
Message 12 of 16
SeattleCADD
Fcerenst!
what is your email address?
Message 13 of 16
fcernst
Info@ernstengineering.com
Sent from my iPhone
Fred Ernst, PE
C3D 2024
Ernst Engineering
Message 14 of 16
fcernst
That Corridor was corrupt. I deleted it and created another one with your same assembly in this region, and it works:
Fred Ernst, PE
C3D 2024
Ernst Engineering
Message 15 of 16
SeattleCADD
Could you please send back me the file!
Message 16 of 16
fcernst
I didn't save it, but I did nothing more than delete that Corridor after seeing the corrupted behavior, and create a new Corridor using your Assembly.
Fred Ernst, PE
C3D 2024
Ernst Engineering
Rail Community
