Civil 3D Forum
Corridor and assemblies from polylines
2 REPLIES 2
strsi681
218 Views, 2 Replies
Hi Everybody,
If the designers are kind enough to pass on a digital design file (usually DXF) then I would like to be able to convert this data into:
1) Alignment (easily done)
2) Corridor (easily done minus the assembly)
3) Assembly (Cannot figure this part out)...
If you were given design road data by a dxf file what process would you go through to produce the required Civil 3d elements?
Thanks in advance,
Strsi681
2 REPLIES 2
Joe-Bouza
in reply to: strsi681
If none of these elements were provided then what exactly is in this "design" dfx file ?
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People)
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win10 OS
mathewkol
I guess you'd just have to start from scratch using the appropriate subassembblies that come out of the box, or create your own when they don't.
What kind of work will you be doing with this data? Has it already been designed and you have to design it again? That is what it kind of sounds like.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Rail Community
