i have a corridor named "A". i have an alignment named "A" that the corridor is assigned to. i have a new alignment that is just a little different named "B" that is basically right on top of it. is there a way to use "B" instead of "A"?
Solved by el.Topo. Go to Solution.
in toolspace right click your corridor and click properties
switch to the parameters tab and choose your new alignment and profile.
