Hi guys, i creating civil 3d based earthworks calculations, i got it i need to fill. I think i do everything right (Creating EG, subgrade and my project surface), but my boss says, that civil calculates bad in this case. Can someone help me. I atach my civil file, with xrefs. Its a football stadium. Dont look at the black lines in xref, it just architects suggestions.
Based on what certitude and assumption does he make that declaration?
He should back up his statement with calculation. Or you should defend your position with calculation. Some one is wrong, him or you. You need to determine who that is.
What version of the software are you using? What percentage of the volume does he claim you're off by?
Allen
Allen Jessup
CAD Manager - Designer
It appears that the OP has calculated volumes both ways. There is a volume surface comparing existing ground to "Sankasa" which appears to be subgrade. The reported volume is 3,134 m3 I used the old REPORTSURFACEVOLUME tool to check this and got exactly the same answer. There are also sections in the drawing with materials already computed. The volume reported there is 3,133 m3 - essentially identical.
The only problem I can see is that the design corridor includes lanes only, no shoulders, ditches or excavation slopes to daylight. Without those the calculated excavation volume is going to be short. We could also argue about shrink and swell factors but this design appears to be cut to waste, so they're not really relevant.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
I got those 3144 m3 without digging the soil 20 cm. So i made raise lower surface -0.20 and i got 1555 m3. My Project manager says, that it should get like minus something m3. Do u think i made my assmebly wrong ?
Well he counted fast, and he got about -2100 m3. I dont know, iam new to this stuff, so i really need yours guys help. To make sure, where iam making mistake, or he. You know, its hard to argue with yours project manager, when u are not 100% sure by yourself, so 🙂
