I don't know when this started happening, but i have a drawing that always crashes whenever I try to copy or cut anything. It is drawing specific. Anybody have any ideas? The drawing contains tons of C3D entities.
I don't believe the clipboard is really supported for C3D objects. It will work with some objects but not everything and you may be bringing a whole bunch of dependent C3D objects along for the ride. Are you coping Acad objects or C3D objects? If C3D objects reply with specifices. Copying a coridor will bring in the alignments, profiles, assemblies and it may be too much data for the clipboard. If you are copying a Feature line from a Grading it may just crash.
Acad objects work fine as long as the data isn't overload.
John Mayo
I'm just trying to copy a polyline.
That should work without issue. Have you recovered or run audit on the file?
The WBlock command may not solve the problem but you should be able to keep working.
John Mayo
Yes, i've tried recover and audit to no avail. I'm in the process of getting this hotfix installed:
and this
I will update if I have any luck.
If I try to wblock anything, the drawing crashes.
Here is a screen shot of the error I recieve when I try to use the copyclip or cutclip command
