Civil 3D Forum
copy tool palette
8 REPLIES 8
Message 1 of 9
brow931
376 Views, 8 Replies
copy tool palette
I am trying to copy my tool palette from the design center from Civil 3D 2013 to 2014. I did this in the past and can't remember how. Does anyone remember how to copy tool palettes between versions.
Scott
8 REPLIES 8
Message 2 of 9
Matt_Haokip
in reply to: brow931
Hi Scott,
You may want to refer to the following help document.
http://docs.autodesk.com/CIV3D/2014/ENU/index.html?url=filesACD/GUID-CF1117E9-DD3B-4E79-9333-41D5E63...
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Matt Haokip
Message 3 of 9
Joe-Bouza
set the search path in options?
Your Name
Your Name
Message 4 of 9
brow931
in reply to: Joe-Bouza
What search path are you referring to?
Message 5 of 9
Joe-Bouza
The one where your custom tp are located?
Your Name
Your Name
Message 6 of 9
brow931
Are you referring to changing the path location to point toward an older version of C3D? I know that you are not suppose to copy from older versions into the new version. Would this work the same way? You should be able to just migrate the tool palettes between version. There is a custom migrate dialog box but that doesn't come up either.
Message 7 of 9
Joe-Bouza
No not at all. I assumed you have custum palettes with non c3d elements on them. Why would you want earlier version c3d palette?
Your Name
Your Name
Message 8 of 9
brow931
I have custom non C3D palettes in 2013 that I want to be in 2014 but I don't want to link every palette back to 2013. I want to use the new palettes and still be able to see and use my custom palette.
Message 9 of 9
Joe-Bouza
OK.
When you made your custome palletes did you make them in drawings in a central location i.e server?
Were you sharing them before?
If you had previously exported the pallet info you would want to add that path to the list.
Also look int Matts suggestion.
Your Name
Your Name
Rail Community
