Civil 3D Forum
Copy Surface
3 REPLIES 3
344 Views, 3 Replies
Copy Surface
I want to copy a surface and rename it prior to merging surfaces. What steps do I require to copy.
Many thanks
Hans
3 REPLIES 3
apweng
Use the AutoCAD copy command.
You'll see the new surface in the prospector tab of the toolspace.
Andrew
excuse my ignorance, but can I copy a surface from the list of surfaces in the prospectors tab?
When I copy the surface in the drawing as mentioned earlier, what next step do I make to bring it into the prospectors tab?
apweng
You can't copy the surface from prospector - hence the AutoCAD copy command. You'll see the new surface in the prospector list and you can modify the properties of that one to rename it.
Andrew
Rail Community
