Show only
Search instead for
excuse my ignorance, but can I copy a surface from the list of surfaces in the prospectors tab?
When I copy the surface in the drawing as mentioned earlier, what next step do I make to bring it into the prospectors tab?
You can't copy the surface from prospector - hence the AutoCAD copy command. You'll see the new surface in the prospector list and you can modify the properties of that one to rename it.
