Civil 3D Forum
Welcome to Autodeskā€™s Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
copy paste problem from autocad 2014 to autocad civil 3d 2012
4 REPLIES 4
THEBOLT
930 Views, 4 Replies
Hello there,
I am currrently using autocad civil3d 2012 and autocad 2014. when i try to copy polyline or block or whatever from acad and paste it to c3d, result is paste clip. actually i want to paste to original coordinates from acad to c3d. before, it worked fine (using acad 2011 and c3d 2010). Can anyone help me ?
thankyou
4 REPLIES 4
sboon
in reply to: THEBOLT
You're trying to paste from a newer dwg file format to an older one.  2011 and 2010 were the same dwg format, but it's not going to work in this case.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
antoniovinci
Try using the _COPYBASE and _PASTEORIG commands, as long as working on plain Autocad....
THEBOLT
in reply to: sboon
i got it, im using same version of acad and civil 3d now. thanks.
tdinkins
Just create a WBLOCK of whatever Polyline you are trying to copy from 2014 to 2011 and make sure that you save it as a C3D 2010 format.
Rail Community
