Is there a shortcut for copying a line to multiples of the same object or shapes at once at different locations in the drawing?
@kchungcok wrote:Is there a shortcut for copying a line to multiples of the same object or shapes at once at different locations in the drawing?
My rule of thumb: if there is more than one instance of an object it should be a block. That being said it they were blocks you would be done before I could type this. Not being blocks you will have to resort to snapping. Note preceed the copy command with MULTIPLE may help
It sounds like you want the ARRAY command.
Can you describle how to use the command? Because I tried to use the array classic and it doesn't do it how I want it to be. Even the copy command cannot do this. Maybe I'm not doing it right.
