Civil 3D Forum
Copy command making lines unselectable
7 REPLIES 7
Message 1 of 8
kmedeiros1
461 Views, 7 Replies
I have text from dt command, circle and leader line.  After selecting them I use the copy command and starte pasting all over my drawing.  Probable about 6 copies.  about 3 or 4 of them end up not being able to select them.  So if i want to edit the text, move all three entities or just delete them i cant.  I figured out the only way to delete these "unselectable" objects i copied is to only have that layer on, type selectall and delete.  any ideas on why this happens and why if i did 6 pastes it only happens to 3 or 4 of them? does it have to do with feature lines? I do have 3d lines in this dwg but i should still be able to select what i copied.
7 REPLIES 7
Message 2 of 8
wfberry
in reply to: kmedeiros1
I really never cared what caused things like this.  I just save and re-start Civil 3D.
Bill
Windows 7 x 64 Professional
Nvidia GeForce 9800 & 8500
12 GB Ram
i7 965 @ 3.20 GHz
Corsair Force 240 GB SSD
Infrastructure Suite 2014
Message 3 of 8
palabalo
in reply to: wfberry
I have experienced instability using ctrl shift c, instead use co command.
__________________________________________
Don't forget to mark questions as solved with accepted solutions!
Civil 3D 2014 SP2
Message 4 of 8
kmedeiros1
in reply to: palabalo
it is when I use the CO command, saving and restarting doesnt get rid of the "unselectable" entities
Message 5 of 8
troma
Have you tried:
Recover the drawing?
Audit the drawing?
Close the program and start it again?
Shut down the machine and reboot?
Mark Green
Working on Civil 3D in Canada
Message 6 of 8
kmedeiros1
in reply to: troma
yes all the above has been done
Message 7 of 8
troma
What version are you in?
Does this happen all the time, or was it once only?
If you start a new drawing from your template and draw one line only, and then use the COPY command, does it become unselectable?
Mark Green
Message 8 of 8
kmedeiros1
Civil 3d 2009
It has happened on a two different projects. On two different computers, both civil 3d 2009, one computer is XP the other is Windows 7.  S
Starting a new drawing it is fine, or other projects it is fine.
Rail Community
