*Antoljak, Strahimir
Message 1 of 2 (93 Views)
copied surface styles
93 Views, 1 Replies
11-05-2003 11:14 PM
when a Surface style is created
using Copy Current Selection in the
Surface Properties dialog box and
made current - in the Settings Tab
of the Toolspace, under Surface
Styles, that object gets an orange
triangle marking it as applied -
expected behavior.
Now if I apply back the original
Surface style, that small triangular
orange indicator does not switch
back - rather it stays with the copy
of the Surface Style wrongly indicating
what Surface Style has been applied.
thanks,
Strah @ Langan
*Sanders, Henry
Message 2 of 2 (93 Views)
Re: copied surface styles
11-07-2003 01:57 AM in reply to: *Antoljak, Strahimir
Strah,
I have created a defect for this behavior. Some object styles, Parcels for
example, will display the reference icon following a refresh of the feature.
Surface styles will update following a save and re-opening the drawing.
Henry
Henry Sanders
Autodesk ISD Civil Test Development
"Strahimir Antoljak" wrote in message
news:smileyvery-happy:112A0F3C255D1B278B325FF5C84583A@in.WebX.maYIadrTaRb...
> expected behavior.
> thanks,
> Strah @ Langan
