Hi:
I have received from the client a drawing with points within the file. The values of coordinates and elevations on the panorama tab -they are displayed after I select "All points" icon- are OK but the units are in imperial. How is possible to change the format to metric? I hope that I keep the value anyway.
For a better reference, please check the word document attached
Rafael
Solved by Jay_B. Go to Solution.
Am I understanding correctly that you want to keep the coordinates in feet but display them in meters?
Allen
Allen Jessup
CAD Manager - Designer
Rafael,
Those foot symbols are read from the"Drawing Settings".
Settings Tab of Toolspace > Right click on dwg name > Edit Drawing Settings > Ambient Settings >
"Coordinate" (change to Meters)
"Elevation" (change to Meters)
Please be aware this simply displays the values in Meters and doesn't do any Imperial to Metric conversion to the drawing such as scaling etc.
There may be other conversion issues needing attention.
Rafael,
Glad things are working for you. The one thing I'll mention is that if this is a metric based job and was created in an imperial based template. You may run in to problems with any labels you might use. It literally can take thousands of changes to change every style from feet to meters.
It this is the case. I'd suggest doing a copy/paste in to the correct metric template.
Allen
Allen Jessup
