I am using civil 35 2013. I have a drawing in NAD83 3tm centered on 111d meridian. I have recieved Lidar informnation in XYZ format but at UTM zone 12 metric co-ordinates. When i try to create a point cloud using all the infomation it brings in the point cloud at the UTM co-ordinates. If you check the properties of the point cloud the co-ordinate system for the drawings correct but the cload shows up as none. I had this problem with civil 11 and 12. I can bring in the points in a UTM drawing and quaery the linework to match, but can not transform points to linework.
Solved by l_canning. Go to Solution.
Ensure you choose coordinate system when importing lidar and your dwg is set properly to 3tm which may not be in the list?
