Civil 3D Forum
Coordinate System
12 REPLIES 12
Message 1 of 13
asuspub
499 Views, 12 Replies
Coordinate System
Hi there, how can I show coordinate on Civil 3D?
I inserted a map from google earth and I want the coordinate to be there.
Could anyone guide me on how to do that?
Thanks.
Appreciate your help.
Civil 3D 2012 SP1
8 GB Ram
i7-2630 @ 2.0 GHz
64 Bit Window 7 OS
12 REPLIES 12
Message 2 of 13
jmatte2004
in reply to: asuspub
what i have done in the passed was under the labels command under the note catogory was create a label style that would label the coorinates and selected the point i wanted to label. it was fairly simple process.
Message 3 of 13
d_reno
On the Toolspace panel select the Settings tab, right click the drawing name at the top, and Edit Drawing Settings. there you will find a way to set the coordinate system in your drawing so that you can lebl lats/lons, if desired. Play with the Note label styles (Add Labels>Note) to customize one to display the data you want - either lat/lon or X,Y, presumably.
All this is assuming that whatever you brought in from Google Earth is in the correct location in the drawing, coordinately speaking.
David Renaud, RLS
C3D 2012 on 64bit Win 7 all up to date
Dell Precision 7core 8GB RAM
NVIDIA Quadro FX 1800M
LDT/C3D user since release 12
Message 4 of 13
antoniovinci
Command: _MAPTRACKCS
Message 5 of 13
asuspub
in reply to: d_reno
Thanks for your reply. where can i Play with the Note label styles?
Civil 3D 2012 SP1
8 GB Ram
i7-2630 @ 2.0 GHz
64 Bit Window 7 OS
Message 6 of 13
asuspub
in reply to: antoniovinci
um.... what is that?
Civil 3D 2012 SP1
8 GB Ram
i7-2630 @ 2.0 GHz
64 Bit Window 7 OS
Message 7 of 13
asuspub
in reply to: jmatte2004
Thanks for you reply. Could you show me the steps? Thanks.
Civil 3D 2012 SP1
8 GB Ram
i7-2630 @ 2.0 GHz
64 Bit Window 7 OS
Message 8 of 13
jmatte2004
did you get to figure out how to create a label for the coorinate system
Message 9 of 13
asuspub
no, not yet.
Civil 3D 2012 SP1
8 GB Ram
i7-2630 @ 2.0 GHz
64 Bit Window 7 OS
Message 10 of 13
jmatte2004
okay go to lines/curves in the pulldown and select add line/curve labels, on the dialog box under feature select note under the note label style select the buttom to the right to edit the style then on the layout tab under text and contents next to note select that bottom under properties tab you will be able to select to lable northing and easting or lat and long., hope this helps you if you need any thing else me know.
jason
Message 11 of 13
asuspub
hi, can i have your email address? would you please send it to private massege there? thanks a lot.
Civil 3D 2012 SP1
8 GB Ram
i7-2630 @ 2.0 GHz
64 Bit Window 7 OS
Message 12 of 13
j_matte2004
my e-mail is jason@meyerassociates.com
Message 13 of 13
H_survey
in reply to: j_matte2004
hey
how can i convert my drawing to metric ?
Rail Community
