Civil 3D Forum
Coordinate System Variable
36 REPLIES 36
Message 1 of 37
4255 Views, 36 Replies
Hi, my problem of the day is, I want to have a piece of text added to the drawing notes that uses a field (or similar), to list the coordinate system code assigned to the drawing, i.e. UTM83-12.
Does anyone know if there’s a setvar or something that I can use?
I’m in Canada and they have a load of different coordinate systems to choose from, and I don’t want to have to manually enter it for every drawing.
36 REPLIES 36
Message 21 of 37
in reply to: Jeff_M
Speechless - thanks.
Message 22 of 37
Jeff_M
You're welcome, glad I could help.
If you find a response which answers your question, please be sure to accept the actual post which helped you as the solution. This will help future searchers quickly find answers to their own questions. Thanks!
Message 23 of 37
AllenJessup
in reply to: Jeff_M
Jeff_M wrote:
(load "Coordsystem extraction.lsp")
(setusers1)
Jeff,
Should that second line be (setuser1) ? That runs the setuser1 routine in your lisp and give me the correct coordinate system. (setusers1) gives me an error. This is in C3D 2012.
Maybe It's just me. Looks like all others are having no problem.
Allen Jessup
Civil 3D 2012 SP 3 / IDSP 2014
Dell Precision T7400, Xeon CPU 3.16 GHz
Win 7 Pro, 64-bit,12 GB RAM, Nvidia Quadro FX 4600
Allen Jessup
CAD Manager - Designer
Message 24 of 37
in reply to: Jeff_M
Done. Cheers.
Message 25 of 37
Jeff_M
in reply to: AllenJessup
@AllenJessup wrote:
(setusers1)
Jeff,
Yes, Allen. I realized I had not included the s in the lisp as I was typing the reply. I went and changed the lisp but looks like I forgot to save it prior to attaching it so the version without it got posted. So yes, either your correction needs to be done or the name of the lisp function needs to be edited.
Message 26 of 37
edward.winter
in reply to: Jeff_M
Hi Jeff,
Great lisp routine of yours.
Is it also possible to retrieve all the coordinate systems into a list?
I want to use that list to pick from, and I don't want to use the MAPCSASSIGN command in lisp.
Kind regards,
Edward Winter
Message 27 of 37
Hi All,
It might bee too late but I beleive it can help others having same problem. You may use "cgeocs" variable in field to show drawing coordinate system.
Cheers.
Please mark it as a correct answer if it is usefull for you!
Message 28 of 37
CodeDing
Just noticed there was a second page, trying to delete my comment. Answer has been provided with "cgeocs"!
~D
~DD
Senior CAD Tech & AI Specialist
Need AutoLisp help? Try my custom GPT 'AutoLISP Ace':
https://chat.openai.com/g/g-Zt0xFNpOH-autolisp-ace
Message 29 of 37
rwesson
in reply to: CodeDing
HORAY - all things come to he who waits 🙂
I assuming you use Civil 2018....? I'm still on 2015 and connect to shapefiles (SHPs) all the time.
Is all the mapping functionality still there?
I'm nervous about asking to get upgraded and then loose the ability to do the things I can do now.
Message 30 of 37
chrisan
in reply to: Jeff_M
Does anyone know if there is an update to this or easier sollution for Autocad Map 3d 2019? Please
Message 31 of 37
in reply to: chrisan
This did work just fine. Takes a few minutes to setup, but rock solid after that.
Don't use it any more though.
Message 32 of 37
AllenJessup
As @Anonymous suggested. Use the CGEOCS variable in a text or Mtext Field.
Allen Jessup
Message 33 of 37
ssanchezVWWMX
Not sure if you use sheet sets but you can create a SheetSetCustom Property and link a text field to that custom property in your notes.  attached is screenshot of the field being linked to the custom sheet set properties
Message 34 of 37
ssanchezVWWMX
Message 35 of 37
chrisan
Thank you Allen.  This is what I was looking for.  I spent so long trying to figure out what to call it so that I can do a search.
Much appreciated.
Message 36 of 37
CemilYuksel
I know it might be too late. But I saw this post recent.
I could be populate Field. Other/SystemVariable/cgeocs .
cgeocs, system variable uses current coordinate system code.
Regards.
Message 37 of 37
dan_perde
Just a few years late, but there's an out-of-the-box option to get it by inserting a field and point to the SystemVariable category and pick "cgeocs".
Rail Community
