This is a repost from the ACAD 2010 forum. I thought it was more appropriate there, but I never got any responses:
When I open a an old drawing of mine with Autocad 2010 or C3D 2010 I get the following warning.
I don't know how or why the 'LL' system would have been changed. As far as I can tell it is not affecting anything. I have tried saving the drawaing as different coordinate systems or none and the message persists. How does one fix this error and not just suppress the warning?
Solved by IanMcClain. Go to Solution.
I haven't got this message, so sorry that I can't present a solution for your issue.
But if you have the software installed, that was used for creating the old drawing, you could take a look to the coord-definition there and compare it with your current definition.
Anyway, have you tried to search Google with the message? What's about >>>this<<<.
HTH, - alfred -
I just came back to the drawing that was giving me this error. It's still un-resolved, but not affecting anything.
The drawing was created in LDD, but I don't have it anymore.
After contacting autodesk this was resolved by changing the CS of the offending drawing (used NAD83 datum, Latitude-Longitude; Degrees) and saving, then changing back to no datum, no projection (what I started with). The same had to be done for XREFS that were generating the same error.
