What would cause my points northing and easting to be different in the survey database to the imported drawing point.
for example I have a point that has a northing and easting of:
N = 291237.7825
E = 1144905.5914
N = 291237.2000
E = 1144903.3016
in the drawing.
Solved by Jay_B. Go to Solution.
One possibility is the Survey Database default settings are "international Feet" so if the dwt is set to Survey Feet then the coordinates won't match.
A Survey settings file can be created for all users to map to which will contain all desired Survey Database settings.
Edited by
Discussion_Admin
No problem, glad to help, hopefully it wasn't the Baymont Inn link that helped.
