Once I found excellent post about changing coordinate grid
http://gisexchange.typepad.com/blog/2011/05/making-your-layout-look-more-like-a-topo.html
with this I changed placement of coordinates from being outside of a viewport to inside.
However, I still do like this unnecessary zeros in the end of numbers.
Do you know how to get rid of them in a code?
Vasily
Solved by lim.wendy. Go to Solution.
Try changing the LUPREC variable. Yours is prob set to 3. Set it to 0 andyou should get what you need.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
It works, thanks. However, can MAPLOADGRIDSTYLE be changed for the same reason?
Otherwise i nned to make reference system grid, do LUPREC and after MAPLOADGRIDSTYLE.
It is three commands for one thing.
Thank you
