Valued Contributor
rcallison
Message 1 of 3 (626 Views)
Converting Metric to Imperial
626 Views, 2 Replies
09-21-2012 07:51 AM
How do I convert a dwg file from Metric to Imperial?
There is no direct conversion tool or method.  Create a new drawing from an Imperial template and then insert and explode your source file.  You'll probably have to go through it and update or replace all of the metric styles with their Imperial equivalents.
sboon
Message 2 of 3 (622 Views)
Re: Converting Metric to Imperial
09-21-2012 08:01 AM in reply to: rcallison
Distinguished Mentor
rl_jackson
Message 3 of 3 (614 Views)
09-21-2012 08:29 AM in reply to: sboon
Under the assumption that your drawing is say metric state plane coords, you can use Map to pull the data into your impearial drawing see to US survey foot in the same coord system. otherwise just insert / scale the drawing to convert from metric to imperial.
C3D12-13
Win7x64 6gb
