Neilw
Message 11 of 19 (1,780 Views)
Re: Converting from Microstation to AutoCAD
05-03-2011 09:09 AM in reply to: peterfunkautodesk
Regretably we were not able to renew our subscription this year so I won't be able to try the new feature. I could post my .rsc file if you'd like to try it. I would love to see how it works in Autocad as well if possible. If the converted styles function properly it could be a selling point to management.
Neil Wilson (a.k.a. neilw)
Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
WIN 7 64 PRO
HP Pavillion h8xt, i7 2600, 12 GB
RADEON 6450, 1 GB
http://www.sec-landmgt.com
Employee
peterfunkautodesk
Message 12 of 19 (1,767 Views)
05-03-2011 10:16 AM in reply to: Neilw
This is in Civil 3D 2011 as well...
Peter Funk
Peter Funk
Active Member
blasman123
Message 13 of 19 (1,288 Views)
12-28-2012 12:40 PM in reply to: Karon.williams
Peter,
Where can I get this API from Bentley. The one that converts MIcrostation Linestyles to Autocad?
Sonny Gonzales
New Member
jnavagh
Message 14 of 19 (1,172 Views)
02-19-2013 12:55 PM in reply to: Karon.williams
I have been testing the use of this conversion feature, and it seems fine when the file is first imported.  However, when saving the file and closing, and then re-opening, the linetypes have been washed away and I am left with continuous lines where my microstation linetypes once were.  The linetype is still defined in the "Linetype" dialog, however the graphics simply loom like a continuous line.  Any thoughts?
New Member
balkisusa
Message 15 of 19 (1,150 Views)
Re: Converting linetypes and styles from Microstation to AutoCAD 7
02-21-2013 07:19 AM in reply to: Neilw
our client sent us dng files which I was able to convert to CAD 7, but my linetypes are not plotting right. The client sent us also all the linetypes and standards but in microstation format. How do I transfer/convert these standards so I can create the correct plot style so my drawings will plot correctly?
Valued Contributor
civ_engineer
Message 16 of 19 (944 Views)
08-14-2013 08:36 AM in reply to: Neilw
Did you find a solution to this problem?
I just used NCOPY to bring in a microstation linetype
and had the same result of getting the continuous line upon
reopening the drawing.  I'm trying to make a double yellow with the
inside dash... using a shape created in autocad produced pitiful results.
Neilw
Message 17 of 19 (942 Views)
08-14-2013 08:46 AM in reply to: civ_engineer
I haven't gone through the workflow, but as Peter metioned above, you'll need to put the microstation linestyle file (.rsc) in the Autocad files path for the translation to maintain fidelity. So I would conclude you'll need to get the .rsc file from the DGN source.
WIN 7 64 PRO
RADEON 6450, 1 GB
Valued Contributor
civ_engineer
Message 18 of 19 (928 Views)
08-14-2013 12:29 PM in reply to: Neilw
That didn't work for me.
Neilw
Message 19 of 19 (924 Views)
08-14-2013 12:41 PM in reply to: civ_engineer
I'd file a support request with reference to Peter's comment in this thread.
WIN 7 64 PRO
RADEON 6450, 1 GB
