Civil 3D Forum
Converting Expressions with ??? to some thing useful
2 REPLIES 2
ralstogj
307 Views, 2 Replies
Hi
I am trying to create a label for slopes in cross sections for a surface created from breaklines using gade breaks as you can not weed segment labels
I am weeding the labels out based on the change in grade of the section profile and making the label text high very small of the labels I do not want to see. But the first label returns ??? because there  is no grade coming in so I get ??? instead of something usefull like null. Has anyone found away to convert ??? to something you can evaluate and use.
Regards
Justin Ralston
http://c3dxtreme.blogspot.com/
2 REPLIES 2
peterthomson9209
in reply to: ralstogj
You are a very clever bloke Mr Ralston, no doubt.
i have experienced this issue on cross-sections and believe the answer to be that AutoDESK could give a label filtering selection that would include feature lines only on surfaces created from corridors.
This way you would get cross-section labels at feature line locations only rather than all grade breaks...which are effectively where the cross-section crosses a surface triangle.
As to how to get the answer you want?  I have no idea.
nice chatting tho..
won't be long til the snow is at your ankles.
PT
cheers,
Peter T
Dunedin, New Zealand.
C3D 2011, Win 7, Dell M6500, 8Gb RAM
ralstogj
in reply to: peterthomson9209
Maybe of interest to you PT
http://c3dxtreme.blogspot.co.nz/2012/04/civil3d-sections-composite-surface.html
Regards
Justin Ralston
Rail Community
