Greetings! In Civil3d 2011, I started to play with the point cloud to take the ddf files to create surface. What I am curious to know is that the DEMs are in meters and I am looking to work in US feet...it would appear that if I have my drawing setup for the same zone and projection and I specify that the ddf are to be in the same format, does that mean that point clouding converts the meters into feet and places the file into the proper coordinate system? I am not sure if I need to make any adjustments or where to begin to verify that the information is good and viable to use for preliminary project work. Thanks! PS I did go through the tutorial and this was not addressed.
I wrote a blog post on this topic a while back and I remember coming across an issue something like this. I believe the solution was to create a regular surface and add the DEM file to it. If you create a surface from a DEM file, things acted weird.
http://civil3dplus.wordpress.com/2010/02/02/using-dem-information-in-civil-3d/
just a thought, what happens when i bring in the DEM in one dwg, then insert that dwg into a new dwg as a BLOCK, with a Z scale of 3.2808?
never mind, just tested it myself, doesn't convert the verticals that way...
Brain -
That was a great post and I was able to follow it. I did also read the comments from neilw in regards to seamless data and I could not find the DEMs as well. Perhaps if you could shed some light on how to extrapolate DEMS, that would be helpful as well especially if there is no difference between the NED 1" and a DEM.
Also, I wanted to see if your method would be duplicated by using point cloud and the boundaries line up beautifully between both methods. However, I am confused as to why the surface created by the point cloud would yield additional contours compared to creating a surface and importing the DEM directly into a surface yields fewer? Does the point cloud make additional assumptions than directly importing the DEM into a surface? Which would be more accurate (I know that is not the correct word)? When looking at the tutorial for point clouds, the purpose of the point cloud is to extrapolate elevations of objects from its surroundings. To me, the point cloud then in this case would yield a better representation of the surface in that regards. What are your thoughts?
PS I did make sure both surfaces were drawn using 20' minor and 100' major. That would be silly if I did not do that
Brian -
I went back to check out contours on the DEM that I imported because I know the area well. Doing your method was correct in terms of the vertical scale conversion from meters to feet however the surface created by the point cloud was a little over 3 times what the elevation should be for the same contour (not consistent like 3.27x, 3.125x, etc.). Have you ran into this as well?
Honestly, I haven't touched a DEM file since I wrote that blog post and I haven't had the chance to use the new point cloud tools in Civil 3D so I'm sorry I don't have an answer for you on that.
I am glad my blog was able to help you out though. It's nice to see it's worthwhile.
Anyone found a solution to this. I too can't get the elevations to come in correct. Here is a screen cast of my problem [ http://screencast.com/t/D3Zd1VNuGxEG ]. As you will see my elevations should be around 30, but they come in at about 9.
I belive Brian had something posted earlier that may be helpful (first page). If that did not work for you you may want to try following blog post that explains in details what needs to be done and how: http://beingcivil.typepad.com/my_weblog/2011/02/import-metric-dem-file-into-imperial-drawing.html
Good luck!
Thanks for the post. Yes that works...but wow what a work around. For a big surface this takes forever. However, this is a valid work arouind.
I've found that it doesn't look like you can change the coordinate system, but if you pick where the elipses dots should be they appear and you can then select the coordinate system.
HTH
Matt
Thanks for that blog. Setting the DEM file settings in the dialog box was indeed the one part I was missing. Metric to Imperial is some steps. Open Civil 3d metric. The DEM file I downloaded (a geotiff) had missing information attached to it. I had to go to the website I downloaded from (for me MASSGIS) and read up how the file was created to get the correct georeference data. Some info was also extracted from the auxiliary html files I had with the download. After I input the correct info in the "add DEM data" dialog box, everything came in correctly. I then exported that surface using LandXMLout. Opened Civil3D Imperial then used LandXMLin to bring info into feet. Thank you.
