I am doing a little trial and error on possibly converting a drawing from .ctb to .stb. When we start a new drawing, it will be started using named plot styles so it shouldn't be an issue. But there are times when we receive a drawing from someone else and need to convert it.
The first thing I did was convertctb to create a conversion .stb. Then I used convertpstyles to convert the drawing to named plot styles. For the plot style table I chose the conversion .stb I just created because it needs a color mapping table.
But I don't want to use the converted .stb table, I want to use my company plot style. So when I am in layer properties manager, Plot Style is still grayed out and I can't change it.
When I type in pstylemode, the default is 0 (read only). How do I change it so it's not read only and I can use my own plot style table?
thanks. Caryn
Solved by AllenJessup. Go to Solution.
From what I see convertpstyles toggles pstylemode.
Take a look at http://forums.augi.com/showthread.php?t=17135
And this http://docs.autodesk.com/CIV3D/2012/ENU/filesACR/WS1a9193826455f5ffa23ce210c4a30acaf-4cf4.htm
Allen
Allen Jessup
CAD Manager - Designer
Right. And I've seen the link you've listed. I have followed what I thought were the correct steps, but I still keep getting my plot styles read only.
Is your company plot style a CTB or an STB? If the pstylemode is set to 0 that is correct for an STB. I don't know why it's still grayed out in your layer manger. But I don't think changing the variable will do that. You can toggle pstylemode by using convertpstyles, but I don't think that's what you want.
Check your page setup manager and see what plot style is set.
Allen
Allen Jessup
We are beginning to use .stb but we will have to convert from .ctb on occassion.
I went to pagesetup and modified my current page setup to use my .stb (instead of none like it was set at) and that worked. Thanks!
Caryn
You're welcome. Glad it helped.
Allen
Allen Jessup
