We are in the process of upgrading our existing 2009 environment to 2011.
We will have a period where both environments should coexist.
"Saving as" to 2007 format is providing us with Proxy objects in 2009 version even if the Proxygraphics=1 and ProxyShow=1.
Does anyone have a solution for this issue?
Civil 3D has never been or will be backward compatible. So, the only answer is, let the 2009 users go as far as they can then pass it along to the 2011 users. Sorry, but there are no other realistic options.
There are numerous other posts in this DG about this if you care to search.
Bill
I'm pretty sure more than numerous eh Bill?
The only thing I would add is if you need the graphics to be available in 2007 file format you can use "ExporttoAutocad2007" this will explode your Civil 3D entities and at least push the "picture" back to 2007. No Civil 3D intelligence but the stuff should look as it did in 2011.
