Civil 3D Forum
converting an alignment to a shapefile in C3d 2011
11 REPLIES 11
Message 1 of 12
wbcad21
673 Views, 11 Replies
Can someone suggest a method for exporting an alignment as a shapefile in C3D 2011?  Any help would be greatly appeciated.
11 REPLIES 11
Message 2 of 12
tcorey
in reply to: wbcad21
You can explode it down to a polyline object and then use Mapexport to export the polyline. The type of export will be Line.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 3 of 12
sboon
in reply to: tcorey
Don't explode it - offset 1m right then 1m left to create a polyline copy of the alignment.
Steve
Expert Elite Alumnus
Message 4 of 12
tcorey
I agree. That's better than exploding.
Tim Corey
Redding, CA
Message 5 of 12
Murph_Map
in reply to: sboon
Just remember to delete that polyline afterward or you may forget it's there and months from now want to know why your alingment turned into a pline or has a pline on top of it. Now if you want some data in that shp file you can export to SDF then convert that to shp format by importing it into a blank dwg and create Object Data then export to shp format.
Murph
Supporting the troops daily.
Message 6 of 12
ToddRogers-WPM
in reply to: Murph_Map
You can alternatively export civil objects out to an .sdf file as well.  Works better in my opinion...
Todd Rogers
BIM Manager
Blog | Twitter | LinkedIn
Message 7 of 12
tcorey
in reply to: ToddRogers-WPM
Todd, I like this option because it's cleaner than screwing with your drawing by exploding or offsetting.
Once you have the SDF file, don't you then have to import that into a new drawing from where you would use Mapexport to create the SHP?
I notice that when you bring the object back from SDF, it has some object data available. Do you know a way to tell the SDF export which data to include?
Tim
Tim Corey
Redding, CA
Message 8 of 12
ToddRogers-WPM
in reply to: tcorey
Unfortunately there is not way to select objects to export.  I have this on the wish list though!!
Todd Rogers
BIM Manager
Message 9 of 12
Murph_Map
Didn't I say that. 🙂
Murph
Message 10 of 12
ToddRogers-WPM
Haha Murph.  I hope we were posting at the same time.  However, both of our posts are EARLY in the morning (pre-coffee)!!
Todd Rogers
BIM Manager
Message 11 of 12
sboon
You did but Todd has pictures with hi-lighting. Smiley Tongue
Steve
Message 12 of 12
Murph_Map
in reply to: sboon
My screen capture is out of ink. 😉
Murph
Rail Community
