silvernich
Message 1 of 4 (605 Views)
Converting 3D Poly to a Feature line
605 Views, 3 Replies
10-25-2012 01:10 PM
Hello all,
So I am attempting to create a simple grading daylight. I began with a 3D Polyline that has only 2 verticies. When I "Convert Feature Lines from Objects," it creates a feature line with 4 verticies. The 1st and last have the initial elevations from the 3D Poly, but the 2 new verticies seem to be pulling elevations off the surface below where I am working.
My questions are: 1) why are new verticies added? 2) can this be prevented?
I know that I can overwrite the slopes in elevation editor, but this seems like an unnecesarry extra step.
Thank you for your input
Civil 3D 2013, HF3.0
Windows 7, 64-bit, SP1
tcorey
Message 2 of 4 (597 Views)
Re: Converting 3D Poly to a Feature line
10-25-2012 02:15 PM in reply to: silvernich
When you Create Feature Line from Objects, be sure you turn off the option to Assign Elevations.
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
AllenJessup
Message 3 of 4 (569 Views)
10-26-2012 05:41 AM in reply to: silvernich
Or if you need to assign elevations uncheck ie.PNG in the Assign Elevations dialog box.
Allen
silvernich
Message 4 of 4 (510 Views)
10-29-2012 04:12 PM in reply to: AllenJessup
Thank you for your comments. I will see when I run into it again if I can give a more concrete example as both of your suggestions I believe I was already doing.
