Civil 3D Forum
Convert metric 3d polylines to metric feature lines error
2 REPLIES 2
686 Views, 2 Replies
When converting metric 3d polylines to feature lines with units set on metric, drawing properties metric and using the australia/new zealand settings and command "create featureline from objects", for some reason the resulting 3d featurelines end up imperial???
2 REPLIES 2
Jay_B
Unit overrides are possible in the command settings. At the following location are there any Imperial units set?
Check the "Elevation" units.
Toolspace>Settings Tab>Grading>Commands>CreateFeatureLines>
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
in reply to: Jay_B
Yeah that was it, I had to change all values under create feature lines including sub-catagories:
Distance, dimension, coordingate, area, volume and speed.  It turns out the original DXF I was working on was exported out of Vulcan and therefore the settings somehow defaulted to imperial,
thanks Jay,
Kane
Rail Community
