When converting metric 3d polylines to feature lines with units set on metric, drawing properties metric and using the australia/new zealand settings and command "create featureline from objects", for some reason the resulting 3d featurelines end up imperial???
Solved by Jay_B. Go to Solution.
Unit overrides are possible in the command settings. At the following location are there any Imperial units set?
Check the "Elevation" units.
Toolspace>Settings Tab>Grading>Commands>CreateFeatureLines>
Yeah that was it, I had to change all values under create feature lines including sub-catagories:
Distance, dimension, coordingate, area, volume and speed. It turns out the original DXF I was working on was exported out of Vulcan and therefore the settings somehow defaulted to imperial,
thanks Jay,
Kane
