OK, I a little stuck here.
I have an old LDD drawing and all of the Point Blocks are anonymous names. (ie *U###) and I'm trying to convert them to C3D Points. I'm thinking that instead of using the AEC Object they used the Point Block for the Marker.
Is there any way to convert these blocks to C3D points.
Note: When I explode the turn to lines and text only.
Rick Jackson
Survey CAD Technician VI
Solved by Jeff_M. Go to Solution.
If they're anonymous that means they were part of a block and exploded. Point blocks should be named Point I believe. The only way I can think of is to rename one block to point and then convert it. Purge the Point block and then do the next. Sounds painful. I'll think about this. I haven't had my LDD hat on for a while.
They may be old AEC point exploded or Softdesk pointblocks that were blocked together and then exploded. No just tried exploding and AEC Point and you don't end up with an anonymous block. Civil 3D points when exploded yield anonymous blocks.
Allen
Allen Jessup
CAD Manager - Designer
Rick Jackson
Yeah. I've been trying and run in to the same problems. You may end up having to use DataExtraction to create a CSV file. If you find the old LDD project you should be able to reinsert the points from the point database.
Allen
Allen Jessup
Rick Jackson
Here you go Jeff,
I've been playing around with it just can't get a good solution.
Rick Jackson
Attached is a lisp file that will convert the anonymous blocks to Point blocks. These can then be converted to C3D points with the C3D ConvertSoftdeskPointBlocks command. Load the lisp when in the drawing with the points, command name is anon2pointblocks.
Jeff,
I must offer my many thanks and blessings, that just save me countless hours you are a true CAD God.
Rick Jackson
I know this thread is almost 10 years old, but I recently encountered the same issue. I attempted to use the routine you kindly provided, but it didn't work. Could this be due to the newer versions of Civil 3D? My drawing contains more than 5600 points, and creating each one manually would be an endless task.
I took the liberty of uploading the file. I would greatly appreciate any assistance you can provide.
