F2S.lsp generates ACIS solid from 3dfaces
Posted: Aug 23, 2006 9:39 PM
Hi, troops -
Here is F2S.lsp (Face-to-Solid), a companion to M2S.lsp (Mesh-to-Solid).
As in M2S.lsp, the solid is created by projecting each selected face
vertically "down" the CURRENT z-axis to a plane a user-specified
distance below the lowest vertex.
Should work with all version of AutoCAD that support ACIS solids -
actually tested only with 2006 and 2007. Extrudes about 300 faces per
minute with 2006 on a dual-Athlon system, about 1000 faces per minute
with 2007.
Comments and suggestions most welcome.
-Bill Gilliss
Just thought I would add a link to the 7 step solution that autodesk published. No need for the lisp, but not necessarily a better way to do it.
Just incase the instructions disapear in the future.
Convert a Civil 3D Tin Surface to AutoCAD Solid
In some instances, usually for interoperability reasons with other software, you may want to convert your Civil 3D surfaces to AutoCAD solids.
There is no direct way to do this but the method described below will help you do it efficiently.
Now you should have one big solid.
The bottom of the ground is not flat but reflect the top surface
SUBSTRACT a big box if you need to make the bottom flat...
