Civil 3D Forum
Convert C3D to a DGN
11 REPLIES 11
Message 1 of 12
646 Views, 11 Replies
I have a C3D 2013 Site plan with contours, and would like to know if it is possible to convert
this into a DGN Mico Station drawing ?   I am hoping to be able to list the elevations  off the
individual contour lines.   Thank you
11 REPLIES 11
Message 2 of 12
ToddRogers-WPM
You can either do a saveas to a DGN or export it to a DGN file.
Todd Rogers
Message 3 of 12
in reply to: ToddRogers-WPM
Hi Todd
When I save as or export the C3D site plan to a DGN none of the line work created by C3D appears,
unless I explode the C3D drawing first.  Is normal or is there a way do this without exploding the
drawing before exporting it out as a DGN ?
Message 4 of 12
I tried to find saveas to DGN and I don't see it.    Do you really have that ability on your version of C3D?
Message 5 of 12
ToddRogers-WPM
LOL.  Sorry Dan, that is not an option.  I'm not sure what I was thinking that day Smiley Frustrated
Todd Rogers
Message 6 of 12
rkmcswain
Command: DGNEXPORT
Or from the Application Menu.
R.K. McSwain     | CADpanacea | on twitter
Message 7 of 12
When I export the C3D site plan to a DGN none of the line work created by C3D appears,
Message 8 of 12
ToddRogers-WPM
Make sure you are using the correct seed file.
Todd Rogers
Message 9 of 12
the default seed file from autocad to dgn is set in international feet.
Message 10 of 12
Neilw_05
I've not tried to export a C3D file to DGN but it sounds like the C3D objects are not being exploded in the export process. If that is the case then you'll either have to explode them first or export to Autocad then export to DGN.
Another option is to install C3D object enablers for Microstation. You can find guidance for that on the Bentley BE Communities forums.
You might try submitting a support request to get an official solution.
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
Message 11 of 12
gccdaemon
in reply to: Neilw_05
Simple Solution: Export to AutoCAD, then Export that file to DGN.
Andrew Ingram
Civil 3D x64 2019
Win 10 x64 Pro
Intel Xeon E5-1620
32 GB Ram
Message 12 of 12
HansSMS
Export to AutoCAD, then load the DWG into Microstation. Microstation seems to do a better job of importing a DWG than AutoCAD does exporting a DGN.
Hans Moller
Surveying & Management Services
Gladstone Australia
Metabox 16GB, Intel i7-9700K 3.6Ghz, 500GB SSD, 2TB HDD Nvidia GTX 1060
AutoCAD Civil 3D 2018
Rail Community
