Valued Contributor
sswanson
Message 1 of 12 (348 Views)
Convert C3D to a DGN
348 Views, 11 Replies
12-28-2012 10:47 AM
I have a C3D 2013 Site plan with contours, and would like to know if it is possible to convert
this into a DGN Mico Station drawing ?   I am hoping to be able to list the elevations  off the
individual contour lines.   Thank you
TRogers
Message 2 of 12 (342 Views)
Re: Convert C3D to a DGN
12-28-2012 11:04 AM in reply to: sswanson
You can either do a saveas to a DGN or export it to a DGN file.
If the issue was resolved by this method, please click on "Accept As Solution"
*Civil 3DJ*
Todd Rogers
Visit my blog here.
Valued Contributor
sswanson
Message 3 of 12 (313 Views)
12-28-2012 01:57 PM in reply to: TRogers
Hi Todd
When I save as or export the C3D site plan to a DGN none of the line work created by C3D appears,
unless I explode the C3D drawing first.  Is normal or is there a way do this without exploding the
drawing before exporting it out as a DGN ?
*Pro
dgordon
Message 4 of 12 (272 Views)
12-31-2012 07:22 AM in reply to: TRogers
I tried to find saveas to DGN and I don't see it.    Do you really have that ability on your version of C3D?
Dan
Civil 3D 2013
Win 7 Pro x64
Intel Xeon 2.0GHz
12Gb Ram
ATI Firepro 4800
Dell T5500
www.preinnewhof.com
TRogers
Message 5 of 12 (269 Views)
12-31-2012 07:26 AM in reply to: dgordon
LOL.  Sorry Dan, that is not an option.  I'm not sure what I was thinking that day :smileyfrustrated:
*Civil 3DJ*
Todd Rogers
Visit my blog here.
rkmcswain
Message 6 of 12 (262 Views)
12-31-2012 08:09 AM in reply to: dgordon
Command: DGNEXPORT
Or from the Application Menu.
Valued Contributor
sswanson
Message 7 of 12 (232 Views)
01-02-2013 08:55 AM in reply to: sswanson
When I export the C3D site plan to a DGN none of the line work created by C3D appears,
TRogers
Message 8 of 12 (229 Views)
01-02-2013 08:57 AM in reply to: sswanson
Make sure you are using the correct seed file.
*Civil 3DJ*
Todd Rogers
Visit my blog here.
Member
STARMANJER
Message 9 of 12 (184 Views)
01-28-2013 08:42 AM in reply to: TRogers
the default seed file from autocad to dgn is set in international feet.
Neilw
Message 10 of 12 (178 Views)
01-28-2013 09:23 AM in reply to: STARMANJER
I've not tried to export a C3D file to DGN but it sounds like the C3D objects are not being exploded in the export process. If that is the case then you'll either have to explode them first or export to Autocad then export to DGN.
Another option is to install C3D object enablers for Microstation. You can find guidance for that on the Bentley BE Communities forums.
You might try submitting a support request to get an official solution.
Neil Wilson (a.k.a. neilw)
Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
WIN 7 64 PRO
HP Pavillion h8xt, i7 2600, 12 GB
RADEON 6450, 1 GB
http://www.sec-landmgt.com
