AutoCAD Civil 3D General Discussion
Active Member
fiduk
Message 1 of 6 (325 Views)
Accepted Solution
Convert Autocad surface to Civil 3D surface
325 Views, 5 Replies
10-31-2012 01:56 AM
Does anybody know if it is possible to convert an autocad surface to civil 3d surface?
autoMick
Message 2 of 6 (316 Views)
Re: Convert Autocad surface to Civil 3D surface
10-31-2012 03:41 AM in reply to: fiduk
I don't believe a direct conversion is possible, however see http://forums.autodesk.com/t5/AutoCAD-Civil-3D/River-bottom-surface-from-3dpolyline-sections/m-p/360... in which I outlined one way in which 3D geometry could be utilised for a c3d surface.
Cheers
- Mick
Infrastructure Design Suite Premium 2014 (testing 2015 SP1)
Self-built i7-3930K, 16Gb RAM, P9X79 m/board
SSD(system), HDD(data), Win7Pro64, Quadro K4000 (and another with GTX680)
Active Member
fiduk
Message 3 of 6 (310 Views)
10-31-2012 04:05 AM in reply to: fiduk
Thanks Mick! Will explore it.
Best,
Fidel
*Expert Elite*
antoniovinci
Message 4 of 6 (300 Views)
10-31-2012 04:55 AM in reply to: fiduk
The easiest way is to explode the Acad surface, getting a bunch of 3Dfaces.
Finally you add those 3Dfaces to a new C3D surface definition.
*Expert Elite*
troma
Message 5 of 6 (278 Views)
10-31-2012 07:48 AM in reply to: antoniovinci
When you add 3D Faces, make sure to check off "Maintain edges"
Unless you really don't want to.
Credit where credit is due! Give kudos or accept as solution whenever you can.
Active Member
fiduk
Message 6 of 6 (271 Views)
10-31-2012 08:06 AM in reply to: fiduk
Thanks Troma and all of you guys. That is exactly what I was looking for.
Announcements
Need installation help?
