Hi!
Im having problems to controll the slopepatterns. This is espacially visible i corners where the slopepatterns distance is very small. I have tried to fix this in the editslopepattern put i cant get it right. I would like to have my slopepatern every 5 meters. This cant be to hard to fix, rigth?
Im attaching a image to show my problem.
The irregular daylight is correct, since the ground is irregular the daylight projection will be irregular. The question is regarding the slope patern, i would like it to be a consant difference between the slope marks not i every elevation point or something that is connected to the tessalation settings.
My idea is that this is only important when creating triangels, but the slope marks must be seperated from this, or is it?
Im attaching another picture to show my problem.
/Robert
I would like to create a drawing that is readeable on papper aswell, that i dont think this is.
Weeding isnt helping, aspecially since some of my featurelines is a part of a grading and isnt editable.
So anyone got an idea of how to change the slope pattern?
/Robert
Hej,
Samma problem här, det verkar bli en släntlinje vid varje höjdpunkt i en featureline. Dåligt att det ska vara så svårt ... Du har inte hittat någon lösning?
Nej har inte hittat någon lösning, som det är nu får jag ta och exportera featurlinesen och sedan rita ut släntmarkeringar från polylinjerna. Känns som en omväg som är helt onödig när jag redan har fått ut släntmarkeringar fast med "fel" avstånd.
No i havent found any solution yet, as it is right now i have to export my featurlines och draw sloppatterns from my polylines by hand. Feel as a unnessasary detour since i already got my slope patterns but with the "wrong" distance between them
