Civil 3D Forum
Control Intersection slope line
1 REPLY 1
165 Views, 1 Reply
Hi all
Attached file is simple Intersection road. But as you can see drawing, Intersection slope line is overlapped.
Someone said define another alignment then I can do that
but I have no Idea for this
If someone solve this problem, please can help me
1 REPLY 1
Your main problem is the curb returns aren't really correct. When you look at it in 3D you will see your curbs are higher or lower around the returns. You really need to adjust your curb return elevations plus your templates around the NB curb really aren't going to blend very nicely. It see where you have a shoulder on one portion of the curb return. The assembly that you are using there is incorrect. What you did there was attach your slopes to the wrong attachment point so this is also causing you problems.
By all means give me a call or drop me an email if you need some help walking you through this.
Robert Gadbaw 800 247 1927 robertg@theppigroup.com
Rail Community
