Distinguished Contributor
drafter1411
Message 1 of 2 (146 Views)
Contours
146 Views, 1 Replies
01-16-2014 01:40 PM
I can I set contour label precession? I want this 10 not 10.000.
Thanks for any help
Active Member
Hammerling
Message 2 of 2 (140 Views)
Re: Contours
01-16-2014 02:13 PM in reply to: drafter1411
Yes.
This is controlled in the contour label style.
One way to go to the
  • annotate tab,
  • select add labels.
  • in the dialogue box select feature to SURFACE, and
  • label type to CONTOUR any will work
  • click  on the edit icon to the right of the name,
  • select layout tab
  • pick the  right column, 1st row in text,
  • then pick the .... To open a new dialogue box.
  • In the right window, pick in the text,
  • on the left side make your adjustments.
  • !!!!!!!!!!!!!   IMPORTANT    !!!!!!!!!!!!!
    when done click the arrow pointing right to apply these setting to the style.
  • OK out of all the dialogue boxes.
