I cannot get ANY contours to show on my TIN Volume Surface. I have gone under the analysis tab, added the ranges. I have gone back into the surface styles, made sure that under the Contour Ranges, that Use Color Scheme is on.
I have tried two different drawings. I created a new surface in a different drawing and project and tried it there too. I got the elevation banding to work, but not the contours.
Anyone have any other ideas?
Are you using an appropriate contour spacing?
Have you turned off Level of Detail?
neilyj (No connection with Autodesk other than using the products in the real world)
Thanks for the replys.
The contour style I was using works on my regular surface, but not on the volume surface and I have the intervals as 0.1 and 0.5 so it should show up. Checked that all the layers were on, both in the style and in the drawing. The elevation banding works, but not the contours.
I am in Civil 3D 2011, so Level of Detail is not an option.
Any other ideas?
