I built a corridor, then corridor surface. Then I changed the corridor onto a different profile. I noticed that the contours at the end were going crazy: the new profile ended before the corridor and everything was going down to zero elevation. So I went to edit my corridor region. I enter the required station, and my contours disappear.
Observations so far:
If I set the end of the corridor region to 2+377.91 to 2+384.54 inclusive, the contours on the surface disappear. The triangles and boundary still display, and the surface gives a Z reading when I hover the mouse over it. If I set the region end to something above 2+384.54 or something below 2+377.91 the contours reappear.
My profile ends at 2+383.00, and I would like the corridor and the surface to end there too!
C3D 2013 SP1
(I need to edit my signature)
Mark Green
Working on Civil 3D in Canada
Solved by Jeff_M. Go to Solution.
The surface looks fine in the corridor section editor and in the section views.
Mark Green
I left the region end at a station so I could see the contours, regardless of them going crazy at the end. Then I added target profiles for my ditches, and the contours disapeared again. Then I put the region station end to the correct station, et voila! the contours displayed. So I'm happy, for now at least. But I'd like to know what's going on, for next time.
Any ideas?
Mark Green
Do you have a boundary defined for the surface either through the corridor properties or under the surface properties? I think we had a similar problem and once a boundary was added, the surface displayed contours correctly.
Mark Green
Mark Green
Mark Green
